2008 Hummer H2 mirror adjustment motor replacement
Hi team, the mirror adjustments on both mirrors have failed, they do have a little bit of horizontal adjustment but no vertical adjustment whatsoever. I was wondering whether anyone could tell me whether the mirror motors are salvageable and what type of mechanism exists inside the motor. Can they be cracked open and repaired, lubed or whatever to make them operational again?
As far as Mirror Motor GM 19167560 it looks like these are still available.
It would be great to know if these mechanisms can be made to fit earlier models, the connectors may be different however there is a good chance the basic wiring is the same.
If you do go down the replacement route then please post some pictures of your old ones and the connectors.
I have a great deal of information on the 05 motors but zero info on the later ones, it would be great to get hold some to work-out the differences.
Hope this helps..
ok thank you for the step by step instructions above!!! I just fixed it by following your steps, ordering the part etc! THANK YOU!!!! So happy over here!!!
OK GUYS!!!!
this will save you guys with 2008 and 2009 hummer h2's a lot of misery if ur lookin to fix ur driver side and or passenger side mirror motors which have partial or no adjustment activity at all. (THS IS NOT THE MIRROR FOLD FIX)
My driver side mirror lost complete adjustment and my passenger mirror lost up and down adjustment. If you are a 2008 2009 h2 owner you are in luck!!!!
I learned the hard way from hummer forums showing the fix for the 2005 etc and they clearly are not the same fix for the 2008 etc. There was no forum describing the mirror motor replacement for the 2008 etc, well hopefully from my message here there will be one going forward.
unlike the 2005, the 2008 etc does not REQUIRE THAT THE COMPLETE MIRROR ASSEMBLY BE REMOVED FROM THE DOOR!!!!! I did and what a bitch that was. The 2005 does require that the whole complete mirror assembly be remove to get at the motor.
The 2008 requires that you simple remove the actual mirror glass from the motor assembly by taking a flat screwdriver and placing it behind the glass at the inside upper part of the mirror ( there are great youtube videos on this procedure) please watch the videos. there are small plastic clips which all u need to do is pop one loose and the mirror will pop right off. once the mirror is off the round looking dial is or are the motors assembly. remove the three small screws and thats all there is to it. now finding the replacements is simple they are a standard gm part via Tahoe or escalade. they were $60 ea, they were so simple and cheap to buy i replace both the driver side and passenger side motors in about five mins it was that simple. it saved me hundreds of dollars.
hope this will clear up any confusion and put minds at ease.
PeterM
Aug 7, 2011 06:55 PM
