2008 Hummer H2 Air Filter duct assembly complete
Old Nov 25, 2013 | 11:34 AM
dr.drew2's Avatar
Default 2008 Hummer H2 Air Filter duct assembly complete
New zero miles. Removed form my 08 when I bought it. Never used includes air filter $150.00 Located in Ohio
Old Dec 17, 2013 | 09:34 AM
dr.drew2's Avatar
bump to top
Old Aug 27, 2014 | 04:27 PM
dr.drew2's Avatar
bump to top still available
Old Sep 15, 2014 | 10:59 AM
dr.drew2's Avatar
still for sale.
Old Sep 30, 2014 | 02:40 AM
dr.drew2's Avatar
bump to top
Old Nov 6, 2014 | 12:41 AM
mattdillon's Avatar
Did you put a CAI on it when you bought it? Reason i was asking is my K&N is suppose to be here 2morrow & i was wondering how difficult it is to putting it on! I've heard its about an hour to 90 mins. And to call me a Mechanic would be stretching it! Lol! Thanks & GL with your sale!
Old Nov 6, 2014 | 07:45 PM
dr.drew2's Avatar
its a piece of cake to install. open cover remove factory air filter. 3 or 4 bolts beneath. loosen clamp mass airflow sensor. you can do .. maybe one hour first time done less after that. good luck
Old Nov 6, 2014 | 09:19 PM
mattdillon's Avatar
Thanks dr.drew! so its just 3-4 bolts, no hoses or anything like that, that needs to be closed off or anything! i'm assuming the k&n will bolt rite back up to the same bolts?
Old Nov 7, 2014 | 05:59 AM
dr.drew2's Avatar
Default direct bolt on
Direct bolt on same bolts
Old Nov 7, 2014 | 12:42 PM
mattdillon's Avatar
dr.drew, I looked under there & it looks like there's several hoses or plugs & then there's the lil' filter monitor. If I unhook those things & then just bolt the k&n up to it, I'm not going to have any check engine lites or anything else come on? Thanks!
