2008 h2 service 4wd and traction control
Old Sep 26, 2023 | 04:47 PM
This is what I use: Key Fob Programming Without Tech2
Seller sold out(801) on original listing & has a new updated listing.
Old Oct 1, 2023 | 07:22 PM
Mark R's Avatar
Originally Posted by Miketheike08H2
My 08h2 has been randomly showing a service 4wd and traction control and won’t go into any other 4wd modes usually all I need to do is shut the truck off for a while and then start it again and the service light is gone but it keeps happening more and more and when the service 4wd is on the truck dose drive fine anyone else have this problem or any advice please
Had that error on my 09 which I believe is the same drive line as yours with the 6L80E... Turns out it's just the rotating "Select Drive Traction Mode" **** and related internal components. Easy to replace. Plug and Play. But you have to remove the surround Facia to get it out. Comes out easy ..just unplugs.
As told to me by my HUMMER mechanic. He was right and sent me on my way instead of running me thru the dealership and paying thru the nose.
Seems when the the HAL 9000 see's a voltage glitch in that part of the system, it just throws that one code on your dash. "I'm Sorry Dave... That's all the Info you'll get"
Old Oct 1, 2023 | 08:58 PM
Miketheike08H2's Avatar
Do you know the part number for the replacement 4wd **** and the internals
Old Oct 2, 2023 | 10:41 AM
Gavin Costigan's Avatar
If parts-cannoning a **** doesn't work for you, I have used this tool in the past with great success. It is VERY finicky though, but once it works, its the most powerful scan tool you can buy. Just a disclaimer it comes with hacked software that makes your antivirus upset.
Amazon Amazon
Old Oct 2, 2023 | 04:58 PM
Mark R's Avatar
It looks like this.. the Part # for the 09 H2 is 25874227... Make sure if you find one it looks like yours...Is yours and 08?
Heres the one you want but shows out of stock..this is for an 09 . if yours looks like this it's the one.
Most sites ay out of stock.. Keep searching this number.
Look Here... https://www.summitracing.com/parts/s...UaApVaEALw_wcB
Old Oct 2, 2023 | 05:54 PM
Yeah mines a 08 thanks
Old Oct 2, 2023 | 06:04 PM
>25878427 discontinued. Look here for more information & availability>>>25878427, Switch
Old Oct 2, 2023 | 06:17 PM
Originally Posted by Mark R
That looks like the
25878425 25878425
,not oem yet could work, cheap to buy or return for refund if not!
Old Oct 2, 2023 | 08:00 PM
Mark R's Avatar
This is why the VIN # is important. That is the correct part #. But the 09 looks like this. This is my old one.
Also If you get two flat blade small screw drivers and wedge them in the plastic release tabs you can pull the back off. Then get you some ELECTRONIC CONTACT CLEANER .... not just a cleaner but a Contact cleaner enhandcer like this
Amazon Amazon
. I've been using this stuff for years on Pro Audio Mixing consoles when I worked for Yamaha Pro Audio.
Squirt this gack in the **** side between the **** and green circuit board. This will wash the contacts and clean and enhance the conductivity. Work it around and it should renew the switch. The contact trace is printed on the circuit board. Also forgot to add squirt some in the rear green circuit board, there are also a set of moving contacts in there. AND..THERE IS A SMALL METAL BAR THAT RUNS ACROSS THE FRONT AND ACTS TO GIVE YOU A SPRING TENSION FEEL.. IT HAS A HABIT OF FALLING OUT....YOU CAN SEE IT WHEN YOU LOOK AT THE END WITH THE RIBBON CABLES. ONE END WILL STICK OUT OVER THE END OF THE HOUSING.
Old Oct 2, 2023 | 08:03 PM
Also If you get two flat blade small screw drivers and wedge them in the plastic release tabs you can pull the back off. Then get you some ELECTRONIC CONTACT CLEANER .... not just a cleaner but a Contact cleaner enhandcer like this https://www.amazon.com/Hosa-D5S-6-De...003658380&th=1 . I've been using this stuff for years on Pro Audio Mixing consoles when I worked for Yamaha Pro Audio.
rubbing alcohol works too. They’re 95% the same thing. One’s just a rip off.
