New starter I used on Amazon - $51.88 shipped at this time!
Usually I am neurotic about AC Delco / OEM etc- but I will vouch for this one at a bargain price. Works perfectly and installs perfectly. quick tip - when you remove the starter you will see a sensor on the side of block (crank sensor) make sure its not leaking oil. If it is, now is the time to replace as you have to remove the starter to change it. To change the starter you can do easily without any jacks or lifts, you slide under the truck and can reach the bolts easily. Disconnect the battery, remove the nut for the starter power cable, nut for relay and two bolts to remove starter. - that easy. Its literally a 20 minute task. Chris |
Nice truck. You have an Limited Edition truck without the LE steps and LE brush grill. Let me know if you're interested in them because I am selling both. if interested you can text me at 347-452-9938
Originally Posted by mcioci
(Post 372136)
I did the same on my last LE. Personal preference. |
