2006 h2
Very strange shifter and tranny all shift properly only thing is when I put it in neutral it says park on the dash but it is in neutral put in all other gears fine indicator light will not show neutral it passes it up and says park shifting great running great neutral will not light up on dash
probably a bad range selector / neutral switch on the transmission
Neutral dash kite skips to parrk
Never heard if that where is it located
on the side of the transmission behind the shift lever. black module on the shaft of the arm.
Brinxtexh
Ok did this happen to yours or you just know about this .I know it's not a big deal that the dash doesn't go to N the shifter is right and N is N on the ttanny all the other grates lite right .Is it a major ioeration and is the part hard to get thanks
that switch tells the cluster what gear it is in so it controls what you see on the dash. hard? maybe as you have to remove the range selector arm to pull it off. has it happened to me no but i did have to replace the range selector arm because of a shift link bushing issue and sheared the nut off the transmission. cost me 500$ to have the shaft replaced at a transmission shop. the part was cheap but the labour was like 460 bucks
Bronx tech
Bronx tech ok I know exactly what you mean now last year I had to replace that plastic bushing that holds the cable on the gear selector is right behind that on the cable itself right
Bronx whatever
What are you talking about nobody is saying anything bad to you so why you talking like this to me thanks for the info now go see where you gotta go
Originally Posted by Joegrillo
(Post 372756)
All the other ranges lite up P D 321 JUST NOT THE N but it is in NEUTRAL ON THE SHIFTER no problem just the lite not lighting should I deal with it or just forget about it
.How much is the part I cant find it |
(Post 372755)
