2005 H2 Instrument Cluster in KMs
Old 03-25-2008, 11:29 AM
dwaxman1's Avatar
Default 2005 H2 Instrument Cluster in KMs
Looking to find a instrument cluster for my 2005 H2 with KMs being the larger one. I bought my H2 from New York and it is in Miles but I really would like one in KMs since I am in Canada, any idea where I can get one at a decent price, I wouldn't mind the white background one ( i believe the white one is from an 2003, not 100% sure)
Old 03-25-2008, 02:28 PM
Default RE: 2005 H2 Instrument Cluster in KMs
White is 2003 and 2004!!
You can check eBay as I see them on there OCCASIONALLY, or you can change the face completely by getting either a FACE KIT(that's what I got), or a COMPLETE Replacement Cluster(but then it'll have to be programmed) from US SPEEDO. Just MAKE SURE you tell them KM's!!!
http://www.usspeedo.com/
Old 03-25-2008, 02:47 PM
dwaxman1's Avatar
so yours is just a face plate?
Old 03-25-2008, 03:24 PM
finall's Avatar
I am in BC, Canada and just had a US H2 imported by local dealer.
They changed the cluster to metric for me, OEM type. GM has a company called York Electronics in Calgary doing this for the Canadian H2 dealers.
They did a perfect job on it. Changed the faceplate. Call York at 403-207-0202.
If you want aftermarket, you are on your own for finding a metricface.I have only seen imperial faces, but someone may know of metric ones.
Old 03-25-2008, 05:19 PM
dwaxman1's Avatar
thanks BC brother, I am in Ontario and same situation, imported from US and now I want the KMs, I will call them, thanks!
Old 03-25-2008, 07:47 PM
finall's Avatar
No problem. Since they change the bezel, all of your other instruments gauges will also turn into metric.
This includes your gas gauge, so you will not have to convert "full" and "empty" into metric anymore!
Old 03-25-2008, 07:50 PM
dwaxman1's Avatar
the gas tank always confuses me, it is always on empty!!
Ha!
Old 03-25-2008, 11:56 PM
dizzy's Avatar
Hey dwaxman! I am also in Ontario (Etobicoke). My H2 is from Virginia with speedo in mph. Just takes a little getting used to.
Old 03-26-2008, 01:56 AM
ORIGINAL: dwaxman1
Yup!!!
Original underneath!!
Old 03-26-2008, 05:28 AM
dwaxman1's Avatar
Hey dizzy,
I am in Brampton but work in Etobicoke! Hello Neighbour!
Hey Bob where did you get the Faceplate??
Quick Reply: 2005 H2 Instrument Cluster in KMs
