2005 H-2 Dash Restoration
Old Apr 1, 2020 | 04:39 PM
Rick-H-2's Avatar
Default 2005 H-2 Dash Restoration
Gentlemen, I'm in the process of trying to restore my dash parts on my 2005 H-2 (see attached photo). I have sanded all the dash parts with 320 and 1000 grit.. Also, I have cleaned all the parts using acetone.
I have not been able to get the areas smooth as I would like because of the rubber coating. I'm afraid that once painted, the marred and scratched areas will just fill up with paint and will show .
I'm wondering if all the rubber coating has to be removed and if so what is the recommended method. Also, if there is anything other methods that are better, I would greatly appreciate any any suggestions.or advise.
.I would like to think in advance to any of my fellow Hummer brethren that may be able to help.
Rick
Old Apr 1, 2020 | 04:50 PM
Chrmer3's Avatar
I sent all mine out on my last H2 (yellow 2006) that had the same style finish as yours- I had it all coated to "Piano black gloss" the finish came out amazing and is a coating that makes it durable and nowhere near as fragile as the original or painted coatings...
I think total cost was around $500 however the difference in the interior was literally like a new vehicle dash finish, If you are keeping it- I highly advise going that route., I will see if I can find some pics..
Chris
Old Apr 1, 2020 | 04:51 PM
mine did not have a rubber coating when i sanded mine. maybe the acetone is reacting with the paint or plastic. i just used a red scotch pad on the surface to prep it and washed it with soap and water.
Old Apr 1, 2020 | 04:58 PM
Chrmer3's Avatar
pics of dash sent for permanent coating-
Old Apr 2, 2020 | 03:07 PM
LoJac963's Avatar
The factory parts (non-silver or CF look) do in fact have a rubberized coating which is very thin. Unfortunately I think you are in for an immense time of hand sanding if you want to use those stock pieces. I would look into sanding drums/***** you can attach to either air tools or electric tools to make it go faster.
Old Apr 2, 2020 | 07:45 PM
Rick-H-2's Avatar
Chris
Thanks Cmer, I'll post a photo when I'm finished.
Rick
Old Apr 2, 2020 | 07:46 PM
Rick-H-2's Avatar
Thanks Bronx, I appreciate the info bro.
Rick
Old Apr 4, 2020 | 04:02 PM
JAC-H2's Avatar
What is the paint code or aftermarket paint code for the OEM metallic finish. I want to restore mine when I take my dash apart this spring to replace the heater core.
Old Apr 4, 2020 | 05:41 PM
I used rustoleum metallic paint and primer in flat antique nickel. I painted all the trim pieces with it but it is a tad lighter finish then stock but the texture is dead on. you can see the finish in the picture I posted above.
Old Apr 5, 2020 | 08:35 AM
JAC-H2's Avatar
Thanks, that looks pretty OEM to me, nice job, now all you need is new radio and the dash will be perfect.
I have seen restored head units on Ebay.
