2003 hummer h2 / rear side marker removal
Old Oct 2, 2020 | 05:59 PM
sean04h2's Avatar
Default 2003 hummer h2 / rear side marker removal
Hello hummer experts
2003 H2.
I wanted to replace the side marker lights, the front was pretty easy but on the rear side i able to remove the light but i cannot reach and disconnect the wire connector,
i treid to open up the bucket / consul
Inside the trunk to see if I can disconnect it from the inside but i cant open that box either, i cant find any screws on how to open that bucket.
does anyone have any idea?
Please help.
Thank you
Sean
Old Oct 3, 2020 | 11:10 AM
tharber's Avatar
I think you can get to it by removing the wheel well.
Tim
Old Oct 4, 2020 | 06:26 PM
oceanbrave's Avatar
As suggested in my PM to you, just fit inline connectors (see the video in the msg)
Old Oct 5, 2020 | 07:54 AM
sean04h2's Avatar
Thanks ocean,
but i didn't see vids attachment.
Ill look for it.
Old Oct 5, 2020 | 09:35 AM
mcioci's Avatar
Originally Posted by sean04h2
Thanks ocean,
Ill look for it.
on the left side, you will need to remove the roof trim inside truck in rear, and pull away the big trim with the pocket it in behind the jack towards the hatch. the right side is a little easier, you remove the pocket tray and reach your hand up behind the plastic by the glass, pull the cable off the wall and you can replace it fairly easy.
Old Oct 6, 2020 | 06:27 AM
oceanbrave's Avatar
Thanks ocean,
Ill look for it.
It was in the private message where I replied to you.
Anyway its here also
Old Oct 6, 2020 | 06:41 AM
sean04h2's Avatar
Thank you!
Old Oct 7, 2020 | 08:07 AM
sean04h2's Avatar
thank you! I got it all replaced.
Dabondsman
Oct 5, 2020 11:39 AM
rifsm1
Jan 10, 2012 06:14 PM
davyo
May 29, 2009 06:16 AM
ONALLFOURS
Jun 9, 2008 02:19 PM
IYF_H3
Nov 7, 2007 01:51 PM
