2003 H2 seated seat repair
Since it is starting to get a little chilly here is Ohio I decided to repair the heated front seats in my 2003 H2. When the heated seat buttons were pressed on either door they would light up for half a second and then go out. No heat to either front seat. I figured I had a short in one or more of the seat heater elements which I confirmed to be driver's lower heater element only. Problem is the 2003 H2 made the seat heater elements as part of the leather seat cover. $$$ to replace. So I bought a seat heater element for a full size Chevy truck of the same year (GM part number 88940288) and installed it between the foam and the seat cover. Now both heated seats work fine and you don't notice the slight extra thickness in the driver's lower seat.
Good job. did it plug right in?
Yep, plugged right in.
Originally Posted by SafetyRick
(Post 318704)
Originally Posted by mcioci
(Post 318718)
same thing happened to my 2003 H2 heated seats. I removed the pads stitch by stitch and replaced the pads. All is well now. I had the leather guy do this for me when I changed my leather seats last week. Working well now.
Same problem
W/ the heated seats, I see you can purchase them on Amazon, but I'm not big on taking out the seat & re-stitching the heating element back in. Does anyone have an idea on how much this would cost to get it repaired at a local shop?
Originally Posted by Matthew Byers
(Post 355517)
Originally Posted by hummer_on_fumes
(Post 355519)
I was scared to do it myself but it is actually pretty easy. The heating elements come with double sided tape so you don't need to stitch the new one in, just stick it to the foam. It took me a couple hours but I hadn't done it before. You'd be looking at paying several hours labor and the cost of the elements. Most likely an upholstery shop would be where you'd need to take it. But honestly it's an easy job to do yourself.
(Post 355522)
Fair enough. If I can take the time to replace a solenoid in the transmission pan, then this shouldn't bother me so much. Thanks for the quick response. I'm assuming the seats have to come out? Did you get the heaters off of Amazon, or anywhere cheaper? Thanks again for your response.
Thanks!
| All times are GMT -5. The time now is 01:43 AM. |
