'09 H2 ate a push rod
Old Dec 18, 2019 | 09:50 AM
Mule's Avatar
Default '09 H2 ate a push rod
125kish miles. Truck is all stock hardware with a tune. Driving down the hiway and started throwing a p0303 code...found this.
Old Dec 18, 2019 | 10:08 AM
Sam!'s Avatar
Active Fuel Management Lifter problems right?
Old Dec 18, 2019 | 10:21 AM
Mule's Avatar
Not 100% sure yet. I don't believe the L9H in the 09s use AFM. Not sure if they used same lifters.
Old Dec 18, 2019 | 12:54 PM
legerwn's Avatar
the L9H did not use AFM, if its like the 08 L92 the block was cast for it but the oil bores are blanked off by the valley cover
Neal
Old Dec 20, 2019 | 07:48 PM
Mule's Avatar
Order a new push rod... came in a kit w/ TSP vvt1.2 cam, cnc port work for heads, lifters, and a valve stem cap for the front left tire.
Old Dec 21, 2019 | 07:47 AM
legerwn's Avatar
looks like you got it covered, let us know how it turns out
Neal
Old Dec 24, 2019 | 08:23 AM
Mule's Avatar
taking care of cam change while waiting on the heads to get done.
...to change the oil pump you pretty much have to drop oil pan. And what a total pain in the a** that is with motor in truck. 4 bolts are just about impossible to turn more than an 1/8 turn.
And wherever the little oil leak is, nasty. 6 Miller job for sure
Old Dec 24, 2019 | 10:09 AM
might want to replace the oil cooler block gasket above the oil filter housing if you can access it. that could be your source of the leak
Old Dec 26, 2019 | 05:27 PM
Mule's Avatar
bronx, amen to that. I'm changing anything that seals, squeals, sticks, click, clacks vibrates or moves.
Old Jan 13, 2020 | 08:24 AM
Mule's Avatar
Machine shop just went through the heads. Found damage to the valve guide, cracked the seat, beat the snot out of the chamber and deck...new core hunt underway.
