07 H2 SUT Slow fill fuel
Old Oct 15, 2024 | 07:09 PM
Eeeeky's Avatar
Default 07 H2 SUT Slow fill fuel
New to me H2 SUT 50,000 miles.
a blockage in fuel fill system. Takes 10-15 minutes for 20-25 gallons. Fill line or vent line blockage? Where to look?
FYI-tons of great info here.
thanks
Old Oct 16, 2024 | 07:34 AM
Welcome to HF
Old Oct 16, 2024 | 02:27 PM
Welcome to HF. This New Member section is strictly for introductions and NOT for Tech questions ... says so at the top. I MOVED your Tech questions to the H2 (which is more active) than H2 SUT section.
Scan it for historic codes and add the results to your question. Purge Valve or EVAP Vent valve are the suspects.
Read this: H2 Canister Vent Solenoid Repair
Old Oct 17, 2024 | 09:40 AM
LOOK, your first post was made a sticky. Your second one digging up that 10 year OLD Thread won the You Dug Up The Oldest Azzed Thread of the Day Award to tack on your statement that you used the search and found your answer.
Old Jan 1, 2025 | 11:21 AM
2004H2's Avatar
Default Been there,done that…..
thanks
you charcoal canister is plugged up, and the charcoal beads have gone down the tubes going to the fuel tank blocking the lines, I had same problem with my 2004H2, they blew out the lines, replaced the charcoal canister and replaced the check-valve at the shop….cost was around $500.00, I spent a lot of time at fuel pump running on low speed fill because of this issue, also the shop said when you fill the truck and the fuel nozzle pops, don’t fill any more, filling more destroys the charcoal canister, and you have this problem again in no time…..
2004H2
2006H3
Old Oct 16, 2025 | 05:41 AM
Jack America's Avatar
Old Nov 4, 2025 | 11:13 AM
Mikebyrd's Avatar
I had the issue. Fuel tank remove, blow out vapor vent lines, and replace. New charcoal canister $241.35. Total labor $300.00.
JakesSUT
May 29, 2024 05:47 AM
ragged63
Dec 1, 2013 08:40 PM
Humbug2
Dec 19, 2011 02:47 PM
Hotwheels
Aug 6, 2010 06:38 AM
azz7772
May 14, 2007 04:28 PM
