05 h2 ecu
Old Apr 8, 2020 | 09:57 AM
When you contact them tell them what happened? All I know is that you stated you replaced front impact sensors and cleared the codes, yet still have a historical code for the steering wheel module. B0051 is a latched code and there is a way to manually remove the code.
Old Apr 8, 2020 | 06:12 PM
you need to physically check the module it might have corrosion on the pins if you have had water leaking into the drivers compartment. you should also check all your body grounds especially the one near the body bushing under the driver door for corrosion.
Old Apr 8, 2020 | 11:27 PM
Bronx, you are correct! Btw, there are too many fly by nights, that post here! This scenario just don't make sense to me, and ihregistry needs to step up and give more information, to help others in the future. #HFPAYITFORWARD. You have to blow a B0051 into the sdm. However, you can get a B1000 due to contact failure. I'm still confused as to why the impact sensors were replaced and ihregistry never posted the codes for that.
jman1335
Oct 20, 2017 09:05 AM
jman1335
Sep 16, 2017 01:49 PM
gasguzzler4mpgonthetow
Aug 1, 2014 07:12 PM
pteam
Sep 15, 2008 07:39 PM
FLH2
Mar 28, 2008 08:16 PM
