05 H2 - additional work and progress
Old Jun 15, 2020 | 02:53 PM
  #21
Chrmer3's Avatar
did you do the O-ring on the pickup?
Also, now you just need to paint all the red stuff - black
Old Jun 15, 2020 | 03:23 PM
  #22
another source of leaks is the gasket by the oil filter housing where the oil cooler lines go into might want to replace it since you are in the area.
Old Jun 16, 2020 | 05:59 AM
  #23
Daniel Z's Avatar
Thanks for the heads up, I will take a look at that as well. As at matter of fact the majority of the oil leak has been around the back of the oil pan area. And whoever worked on this truck before, didn't tighten the oil pan bolts correctly. I removed half of them with my fingers! Effin idiots.
Old Jun 16, 2020 | 06:02 AM
  #24
Daniel Z's Avatar
about to do the o ring today.
nope, not going to paint it black, I love red too much LOL
Old Jun 16, 2020 | 11:19 AM
  #25
Daniel Z's Avatar
Default O-Ring
As some of you pointed out, the O ring is busted and it's now plastic lol appreciate the advice.
This is the culprit, u made me go thru all this work to get to you, got cha.
Old Jun 16, 2020 | 12:58 PM
  #26
its cracked.... that will definitely cause low oil pressure
did you chose to lift the motor? how are your motor mounts looking?
Old Jun 16, 2020 | 07:45 PM
  #27
Daniel Z's Avatar
Not yet, but I'm planning to take out the engine all together in the very near future and rebuild it and also get that engine compartment worked on. I'll take a loot at those tomorrow and see the condition, but I'm sure those are worn out. This engine has about 200k and I doubt there was any work done on it or around it.
Old Jun 16, 2020 | 10:48 PM
  #28
i have 219k on mine but knock on wood its been ok. so far just needed to replace on the engine is plugs, belts and tensioners with idler pully as they where a set.
Old Jun 17, 2020 | 06:41 AM
  #29
Daniel Z's Avatar
nice, what year is yours and color?
Old Jun 17, 2020 | 01:29 PM
  #30
yellow 2003
