05 h2 4wd shift encoder motor
Old Jan 21, 2023 | 11:09 AM
Rainn5420's Avatar
Default 05 h2 4wd shift encoder motor
I recently attained a 2005 hummer H2 and the 4 wheel drive's not working there is no shifting coder motor attached to the transfer case and I don't understand why. Why is there no shift motor on this transfer case??
Old Jan 21, 2023 | 03:34 PM
who knows what the previous owners or shady dealers have done in the last 18 years to the truck.
Old Jan 21, 2023 | 04:33 PM
Because it failed! Get off your A$$ and crawl under to shift.
Old Jan 21, 2023 | 04:38 PM
Rainn5420's Avatar
It appears to be the right transfer case, but where the shift encoder motor or actuator attaches to the case is sealed, like where the 3 bolts go, there no holes and it's as if the transfer case cover is different. Would there be any reason for this truck to not have the shifter encoder motor attached to the transfer case?? Or do they all have them on the case for the 4wd system? I'll get a pic to show what I'm seeing
Old Jan 21, 2023 | 05:21 PM
Rainn5420's Avatar
Old Jan 21, 2023 | 06:55 PM
BW4484:
Old Jan 21, 2023 | 07:32 PM
Rainn5420's Avatar
In those pictures above is my issue. As you can see there's no shift encoder motor on the trans case and no access for one...what could be the reason?? It's supposed to have a shift motor there right?
Old Jan 21, 2023 | 07:57 PM
Not with a BW4481:
FITS THE FOLLOWING VEHICLES WITH A 4L60E TRANSMISSION
Cadillac Escalade/ ESV/EXT (2003-2006)
Chevrolet Suburban 1500 and K1500 (2005-2006)
GMC Yukon Denali (2005-2006)
GMC Yukon XL 1500 (2003-2006)
Old Jan 21, 2023 | 08:57 PM
Rainn5420's Avatar
So this 2005 h2 i have should not have this transfer case in it?
Old Jan 21, 2023 | 08:59 PM
Rainn5420's Avatar
And if that's the case, my 4wd system won't operate correct?
