**Hummer H2 Belt Noise**
Old Apr 24, 2014 | 08:44 PM
patspano's Avatar
Default **Hummer H2 Belt Noise**
My 2003 Hummer H2 has had a belt noise problem for about a year now, we have tried pretty much everything to fix the problem but it keeps coming back. The tensioner, water pump, idler pulley, and multiple belts have been changed and nothing seems to fix the problem. Before dumping more money into changing parts that aren't going to solve the problem I was wondering if anyone knows what the problem might be. The pulleys were all cleaned each time a fresh belt was put on, and done by a GM mechanic, and the noise does go away for about a week after a new belt is put in but eventually comes back. Once the truck worms up, it won't make any noise when idling, but once the rpms are over 1500-2000 it comes back. I really need to get this fixed, the noise is only getting louder and the truck is embarrassing to drive.
Old Apr 24, 2014 | 09:24 PM
Man1nboat's Avatar
Try belt dressing ($5)...
Old Apr 25, 2014 | 02:46 AM
LoJac963's Avatar
I understand it was a GM mechanic but make sure the belt is routed correctly. New everything including the tensioner so everything should be good. Only thing I can think of is somehow the belt is routed wrong causing it to have too much slack where the tensioner can't take it all out. I've never messed with my belts, pretty sure they are the stock belts and I've never had any problems.
Old Apr 25, 2014 | 08:13 AM
calif phil's Avatar
The best belt for eliminating noise is a Goodyear Gatorback belt.
It could also be a bad alternator bearing.
Old Apr 26, 2014 | 02:51 PM
patspano's Avatar
I thought belt dressing was bad for the belt, I have tried it and it only worked for a few hours, the noise came back even worse.
Old Apr 26, 2014 | 09:20 PM
Man1nboat's Avatar
I use it on all my vehicles...
Old Apr 26, 2014 | 11:51 PM
madmayo's Avatar
Check to see if the beLt is running square. I'm wondering if your alternator or power steering pump is kicked out of line and the edge of the belt is rubbing the side of one of the pulleys.
Check to see that the belt grooves are actually running true in the grooves on the pulleys.
With all thhe parts you've replaced I can't think of anything else or as said above the belt isn't routed correctly.
Just some food for thought. Hope you get this frustrating issue dealt with.
Old Feb 23, 2016 | 06:20 PM
patspano's Avatar
Bit late on this but the Goodyear Gatorback belt fixed the problem, we basically went through everything, checked the alignment on all the pulleys, replaced the power steering pump, alternator, idler pulley, tensioner. None of that seemed to work, I even pulled the belt off and cleaned all of the pulleys, it still made the same squeal. One day i finally got fed up and drove over to Part Source bought a gator back belt, replaced the belt that was on there and it hasn't squealed since.
Old Feb 23, 2016 | 07:23 PM
flyday58's Avatar
We appreciate the update, thanks.
Old Aug 15, 2023 | 07:52 AM
momapapa's Avatar
Solved...Thank you for your responses. Replaced the tensioner assembly with another brand and it worked.
