Who's using the 2" suspension lift?
Old Jul 29, 2013 | 06:35 AM
Zeektribe's Avatar
Default Who's using the 2" suspension lift?
I have found a few different kits and wondering who's running the 2" kit and are you happy with it?
What is the difference be between the $1800
Rubber duck kit vs just the spacers for $350-599
I see there is a ball joint angle shim. Is this nessasary with a proper alienment, or does it help with ball joint wear?
http://www.rubberduck4x4.com/s.....it-c86.htm
Can I get away with this, just the spacers for $350
http://bit.ly/12XcqrK
Also will this negatively affect the handling offroad at steep angles?
Old Jul 29, 2013 | 01:29 PM
up-n-over's Avatar
I would like to know this as well...
Old Jul 29, 2013 | 08:20 PM
2" body lift is the cheapest and best lift. I don't like changing the angles with the suspension lift.
Old Jul 30, 2013 | 07:16 AM
up-n-over's Avatar
I am going to do a Cummins conversion and will also be running 40" - 42" tires. Thus, I will need the body lift to clear the engine, and the extra 2" suspension lift will be needed to clear the tires.
Can the factory suspension settings be maintained while using the cheap kit? Is the only difference between the cheap one and the expensive one the extra shims?
Old Jul 30, 2013 | 07:42 PM
I haven't done a suspension lift but have done body lifts on a couple of H1s. PM hummech. He has done it all and can tell you the pros and cons of each.
Old Aug 27, 2013 | 11:18 AM
MattN's Avatar
3 hummers-
Which body lift kit do you like the best? Easiest install?
Thanks, appreciate your knowledge.
bsg424
Jan 17, 2020 10:51 AM
FilthyKings
May 17, 2012 08:15 PM
triblk6spd
Apr 2, 2011 10:57 AM
quadblaster240
Sep 14, 2009 10:03 AM
schmegeggie
Mar 11, 2009 11:33 AM
