What does a H1 10K to 12K conversion contain?
Old Jan 18, 2022 | 11:45 AM
ggt667's Avatar
Default What does a H1 10K to 12K conversion contain?
What does a H1 10K to 12K conversion contain? Which parts are involved and which procedures?
Old Jan 18, 2022 | 01:47 PM
12.1K half shafts. upper gears in the geared hub, spacers, bearings and you may need to machine the CV joint slightly to eliminate rubbing bewteen the CV joint and the brake caliper. Some 12.1 half shafts have been machined some haven't.
Old Jan 18, 2022 | 07:40 PM
ggt667's Avatar
? 12.1K half shafts,
Do you know the specs for the 12.1K half shafts? Metal type? Strength measures, etc?
on prem: upper gears in the geared hub
Which spacers? Please be specific
on prem: bearings
Can you please specify what was machined? and you may need to machine the CV joint slightly to eliminate rubbing between the CV joint and the brake caliper. Some 12.1 half shafts have been machined some haven't.
Old Jan 19, 2022 | 06:32 AM
Check out Flashoffroad.com. They have a section on repairs and modifications. I am pretty sure they have one on this conversion. It would have pictures and part numbers.
Old Jan 19, 2022 | 12:56 PM
ggt667's Avatar
Thank you!
Here are some details: http://flashoffroad.com/Maintenance/.../halfshaft.htm the latter 4 paragraphs of the page.
Srvnet
Hummer H1
Dec 15, 2021 04:59 AM
TxTim
Sep 7, 2016 03:58 PM
hummonthis
Feb 27, 2012 12:54 PM
antman5006
Jan 17, 2012 07:59 PM
magnumoffroad
Mar 25, 2008 03:18 PM
