Tire Change on Hutchinson Alpha Wheels
Old Nov 18, 2025 | 01:15 PM
abovethelaw823's Avatar
Default Tire Change on Hutchinson Alpha Wheels
Looking for recs on a tire shop in Los Angeles who has experience changing tires on Alpha wheels. Also, how much did you pay?
Old Nov 21, 2025 | 02:12 PM
Don't know about LA. I always took my two Alphas and all my other H1s to Mike Sabaresse at Tustin GMC/Hummer. Mike is still there and Tustin GMC does a robust H1 service business.
Old Nov 21, 2025 | 02:22 PM
Thanks. I recall the last time I spoke to them (~2 yrs ago), they couldn't do it. But, I'll reach out again to confirm.
Old Nov 26, 2025 | 02:34 PM
They can they just may not have wanted to at the time. Tell Mike his good buddy Dave from Texas sent you there.
Might also try Hummercore. They might know someone in your area that will do them.
Old Nov 26, 2025 | 02:43 PM
Yes, I have checked there too. The problem is that the labor gets in to the thousands (plus about $2k for the tires). I know this is the primary reason that people take off these wheels and put on aftermarket wheels. Just was curious to see if anyone had a shop that had experience and was reasonably priced.
Old Feb 24, 2026 | 02:21 PM
linel's Avatar
Originally Posted by abovethelaw823
Yes, I have checked there too. The problem is that the labor gets into the thousands (plus about $2k for the tires). I know this is the primary reason that people take off these wheels and put on aftermarket wheels, especially when working with BMW 1 Series parts. Just was curious to see if anyone had a shop that had experience and was reasonably priced.
If you’re looking for a tire shop in Los Angeles experienced with Alpha wheels, VIP Exotic Wheels, Davis Bros Tires, and Melrose Tires Wheels & Hubcaps are solid options. Prices for mounting and balancing typically run $20–$40 per tire, though larger or run‑flat tires can cost more. Always call ahead to confirm they’ve worked with wheels like yours and check if TPMS service is included.
Old Feb 24, 2026 | 02:33 PM
Thank you!
Old Feb 24, 2026 | 04:06 PM
Last Alpha tire change I did ran about $100/wheel.
Old Feb 25, 2026 | 04:44 PM
Which of the 3 shops that you mentioned was this at?
shotcaller660
Hummer H1
Feb 25, 2024 12:20 AM
adamw
Private 'Wanted' Classifieds
Dec 27, 2023 05:09 PM
DJMIKEYSWIFT
Sep 19, 2013 08:11 AM
EclipseH1
Feb 7, 2011 09:14 AM
GRAYLIGHT
Mar 21, 2009 08:37 PM
