Tire Change on Hutchinson Alpha Wheels
Yes, I have checked there too. The problem is that the labor gets in to the thousands (plus about $2k for the tires). I know this is the primary reason that people take off these wheels and put on aftermarket wheels. Just was curious to see if anyone had a shop that had experience and was reasonably priced.
Yes, I have checked there too. The problem is that the labor gets into the thousands (plus about $2k for the tires). I know this is the primary reason that people take off these wheels and put on aftermarket wheels, especially when working with BMW 1 Series parts. Just was curious to see if anyone had a shop that had experience and was reasonably priced.
If you’re looking for a tire shop in Los Angeles experienced with Alpha wheels, VIP Exotic Wheels, Davis Bros Tires, and Melrose Tires Wheels & Hubcaps are solid options. Prices for mounting and balancing typically run $20–$40 per tire, though larger or run‑flat tires can cost more. Always call ahead to confirm they’ve worked with wheels like yours and check if TPMS service is included.
