Intermittent electrical power failure on H1
Old Dec 30, 2018 | 07:41 PM
VTM111's Avatar
Default Intermittent electrical power failure on H1
I purchased a 1998 Hummer H1 over the summer, 6.5T and in the past month have had intermittent electrical power failure. There is no power at all to even start it up, and then 15 minutes later the power will just come on with no problem. Happens when engine is hot or cold and then it works perfectly not long after. Once it’s running it’s fine, haven’t had power failure while driving. I changed the battery and checked all connections, any idea on what it could be?
Old Jan 3, 2019 | 10:12 AM
pwlahaye's Avatar
Sounds like typical PMD(FSD) failure. I assume your truck has the PMD in the original location?
Old Jan 3, 2019 | 06:47 PM
VTM111's Avatar
To be honest I’m not even sure. I will look more into that over the weekend, thanks!
Old Jan 8, 2019 | 01:59 AM
Chris Fisher's Avatar
I just added multiple grounds on my Hummer, the stock ground on the aluminum frame can get very corroded and was causing major electrical problems.
Everything is mint now!
Old Jan 8, 2019 | 07:16 AM
VTM111's Avatar
Thanks for the info! Can you give me an approximate location of ground on the frame so I can look and see if that’s the case? Hummers are all new to me lol
Old Jan 8, 2019 | 11:54 AM
pwlahaye's Avatar
Drift on over to The Hummer Network and read the first post on advice for new owners as well as the other Hummer forums. When you have troubles, like your electrical problem, check the most obvious things first. In your case, that would be the PMD. You might as well get a spare and mount it in a better position. All PMDs fail in the stock position due to heat. Hope you like cranking wrenches. Hummers are maintenance hogs and require a lot of attention but the several Hummer forums will have answers for any problem you might come up with and we are lucky to have several very good vendors for parts and information.
BoltsFan87
Jun 29, 2015 09:22 AM
lionel90
Feb 12, 2015 09:13 AM
CrazyMD
May 16, 2011 08:02 AM
Linda
Oct 20, 2009 08:10 PM
juanillohummerh2
Jul 18, 2006 12:04 AM
