Found a military hummer, buying advice.
Old Dec 10, 2021 | 08:56 PM
WillDrivesU's Avatar
Default Found a military hummer, buying advice.
Hello! I am new here and recently found a hummer that looks like it's in great shape that I'm looking to purchase. I have yet to see it in person, however he took tons of pictures and just from that I looks great, inside and out. Inside is a little warn, but that's to be expected. He's had it for 20 years and was the 2nd owner. He just recently had a good amount of work done on it, and I'm wondering if it's worth it. His reason for selling is that he's getting older and doesn't use it much anymore. Only minor issues, such as the heater not working, and a Crack in the driver's window. Comes with a trailer, and a ton of spare parts as well as some brand new tires. Is this worth 69k? What's your opinion. And what are things you think I should look for when I go look at it next week? Thanks for your input in advance!
1997 Hummer H1 & Military Trailer
• Brand new 6.5 Turbo “Optimizer” engine (the new GM one that doesn’t overheat) Less than 100 miles on it. Manuel waste-gate by Rubber Duck.
• Brand new 4L80E Automatic Transmission - Less than 100 miles on it.
• Brand new OEM radiator, turbo, water pump, air lines, fuel pump and lots more!
• CTIS works great
• New stereo and speakers with 2 subs under rear seats, and 2 amps. It KICKS!
• “Both” AC units work perfect (needs a heater core)
• Four (4) brand new 40” off-road tires and OEM Jack “new”
• Additional Spare tire on military swing out spare tire rack that lowers and lifts the tire.
• Airlift bumpers
• Predator top rack with ladder.
• Predator 2” body lift and 2” suspension lift.
• Brand new half shafts (and old ones for spares)
• Tons of lights on it, all directions, and new rocker switch panel.
• Interior toolboxes
• ARB almost new awning mounted on rack (used two times)
• 4” SS Cat-back with cat removed (I have the full factory exhaust still in great shape with the Cat -and- a brand new Cat never mounted. This passes smog with no problems.
• Come with a Military issued Humvee tool kit. This is still in the box from the Military, unopened and unused.
• Military rear bumper extension with a pintle hitch, and an additional standard hitch below it for ball hitch trailers.
• Trailer brakes
• Rear camera
• Off-road GPS system
• GPS for the streets built into the stereo head unit
• Two newer AGM batteries (less than a year)
• Built in jumper cables so you don’t have to lift the lid
• Custom built partition for rear storage.
• Tinted windows all around (driver windows are low-e tint to block heat)
• LED headlights, tail lights and markers
ericles1028
Dec 26, 2012 11:40 AM
BakerBBB
Oct 21, 2009 10:21 AM
DsH308
Aug 14, 2008 12:14 AM
