Failed to find CTIS air leak. Any Ideas?
Old Jan 14, 2025 | 01:06 PM
03H1SUV's Avatar
Default Failed to find CTIS air leak. Any Ideas?
The rear tires on my 2003 H1 wagon keep losing air, about 15Psi per day and I cant find the leak. I did soapy water on all the air lines from the compressor to the individual wheels and never found any bubbles indicating a leak. The bead locks are sealed.
my last thought is that the 10 year old tires are losing air somewhere. Anyone else traced any issues like this?
Old Jan 14, 2025 | 01:56 PM
i am not sure if this pertains to your circumstance but it seems to follow the same symptoms. the info is on another forum though
https://www.steelsoldiers.com/thread...eaking.86700/#
Old Jan 15, 2025 | 03:23 PM
Sounds like a hub seal.
Old Mar 14, 2025 | 03:26 PM
TOBASH's Avatar
disconnect your CTS from the tires and see which tire goes flat overtime.
Seems like that would solve the problem if you are certain your CTI system itself is not leaking
The CTIS manifold on these things is also suspect because the Aluminum manifold develops rot under the electronic valves. I personally opened one up and found that to be an issue. I needed to weld the defects and sand them off and repaint in order to restore the Aluminum.
Old Mar 16, 2025 | 06:28 PM
Have you checked to make sure the CTIS disconnects aren't the leak source? Make sure they are completely snap on. Also, they get sand/dirt in them and get stuck open. I have rebuilt several.
2000HummerH1
Hummer H1
Oct 21, 2020 08:21 PM
rhinomike
37
Dec 26, 2014 07:46 PM
jasonsdad
Oct 10, 2012 02:38 PM
barry4x
Nov 17, 2011 08:29 AM
Blaser
Sep 10, 2009 02:25 PM
