doors wont open
Old Sep 10, 2007 | 05:06 PM
rescue1's Avatar
Default doors wont open
..hey guys
...my keyless entry wont unlock just the drivers door
then when i use the key to open the alarm goes
..any body have a starting point to troubleshoot?
type of relay maybe?
thanks
Old Sep 10, 2007 | 07:56 PM
blackstangs281's Avatar
Default RE: doors wont open
There will be some H1 guys around soon
Old Sep 11, 2007 | 01:24 PM
Injunfarian's Avatar
wish I could help but dont have keyless entry on my rig yet... and my locks are kinda messed up as well... hope manny or someone else has some input
Old Sep 12, 2007 | 01:54 PM
axleman's Avatar
Does your keyless entry normally open only the driver door or all 4? If it does all 4, but for some reason only the driver door is not working, then I would look at the locking mechanism in the door and see if it is sticking. Also maybe check the wiring in that door as well.
Old Sep 28, 2007 | 11:12 PM
My keyless entry system unlocks the driver's door with one click and the other doors with a double click. My cargo doors were hooked up backwards so that they locked whenever I unlocked the passenger doors and vice versa so they truck was never completely locked up. I removed the cargo door handle assembly and flipped the plug in around and it worked fine. Haven't had your exact problem but I have replaced lots of actuators and door switches on my 97 H1. Not sure why but there always seems to be a door lock that wants to be independent.
Old Sep 29, 2007 | 09:02 AM
hilljob26's Avatar
a really big hammer
Old Jul 17, 2024 | 11:26 PM
karlacarter14@gmail.com's Avatar
Default 1993 Hummer H 1 door lock issue
I recently purchased a Hummer H 1 1993 year model. The day after buying it the door lock control on the inside of the drivers side door quit working. I tried to manually unlock the back door and passenger door but can not. Fuses have been checked any ideas
Joecool1225
Dec 9, 2014 10:02 AM
ScooterDog
Dec 28, 2013 09:14 AM
frog86
Oct 11, 2013 06:40 AM
lostsoul77
Jul 16, 2013 01:49 PM
bryongaskin
Apr 6, 2008 11:40 AM
