Ctis help please
Old Feb 3, 2015 | 08:38 AM
Peircetrainor's Avatar
Default Ctis help please
So I went to inflat my fronts for the normal loss when I flip the switch with my fronts isolates the gauge spiked from where it was all the way to the pin, I turned it off and it bled back down. Anyone have any idea? I need to get this fixed as soon as possible as we are suppose to get a bunch of snow this week, unfortunately it's currently 0 outside. So any help would be greatly appreciated.
Old Feb 3, 2015 | 06:50 PM
Not sure I understand. The pump cannot inflate the tires that fast. Did the tires actually deflate or did the gauge just go back to normal?
Old Aug 26, 2015 | 04:46 PM
gerry's Avatar
Sounds like a blockage in the lines
Old Aug 27, 2015 | 11:01 AM
V-tek's Avatar
that's normal if you disconnect you CTIS lines, everything but the tire is instantly pressurized. If the fronts are connected, disconnect and reconnect just to check. It would be odd that both front lines are blocked at the same time.
Old Sep 3, 2015 | 08:48 PM
wiretap's Avatar
Could be blockage at your CTIS manifold that goes to the front tires. I would take apart the front inflate valve and clean it out.
Example video for how to clean the valves:
aliciajeanschmidt@gmail.com
Aug 27, 2013 03:42 PM
Dpedersen
May 25, 2011 04:53 PM
Outlaw6Guy
Jan 14, 2008 10:38 AM
finrazr
Mar 19, 2007 02:46 PM
hmcoleap
Aug 22, 2006 01:14 PM
