CTIS going low after sitting for a while
Old Nov 27, 2018 | 10:59 AM
2000HummerH1's Avatar
Question CTIS going low after sitting for a while
Hey everyone,
I have a 2000 H1 that runs and works great. It is a car that I use infrequently and if it sits for a while the front or rear tires will go completely flat. It hasn't happened that both back and front go down, just one or the other. Currently it is just the front. When I get in and air it up, they stay up and work fine, but if it sits for a while it will go down again.
Is this an air hose thing that I should get replaced in the CTIS? I just got it back from the Chevy dealer who replaced the PMB, batteries and went through the rig and said it was clean. It only has about 20k miles on it and is garage kept.
Thanks for your help, not sure if I should take it back to the dealer for this work or find someone more local. I'm in Austin, Texas.
Old Nov 27, 2018 | 06:01 PM
That is pretty normal. As they age the seals and valves get dry and brittle, especially on a truck that isn't driven much. First pop the disconnects at the wheels after the tires are aired up to proper pressure. If the tires still leak down then do the soapy water test. Start at the CTIS disconnects at the wheels. They are easy to check and replace. Spray the disconnects and look for bubbles. Spray the rim also. This should isolate the leak to a specific wheel/tire if the leak is at the wheel. If no bubbles move on and spray the lines and connections back to the pump looking for air bubbles.
If still no air bubbles or leaks found you can disconnect the CTIS line leaving the hub. Put the end in a container of water and if you have bubbles you need to replace that hub seal. You can also have a CTIS leak at the control valve that allows you to adjust pressure front to back. If you have two piece wheels the O ring between the two wheel halves can also leak.
Typing this quickly so I may have left a thing or two out but that should get you started.
There is a really good H1 mechanic in Houston. David Long is his name. I will PM you his number.
Old Nov 27, 2018 | 08:35 PM
Thanks, I appreciate it. I'll give that a shot this weekend and see what I can find. I'll make sure to keep David's information on file too if I need it in the future.
Old Aug 4, 2020 | 06:05 PM
MatlockG's Avatar
Hi - brand new to the forum and in need of a Houston H1 mechanic contact. I’ve seen David Long’s name mentioned- do you by chance have his contact? Thanks!!
Old Aug 5, 2020 | 08:03 AM
PM Sent
Old Oct 21, 2020 | 08:21 PM
TXH1's Avatar
Hello could you please send me contact info for David Long?
Boneclover
Hummer H1
Feb 12, 2021 10:30 PM
2001H1OPENTOP
Jan 9, 2016 11:41 PM
barry4x
Nov 17, 2011 08:29 AM
uc5673
Jun 8, 2009 12:06 PM
YTH1
Feb 21, 2008 06:57 PM
