Coolant leak
Old Nov 28, 2024 | 11:46 AM
Biggdadd58's Avatar
Default Coolant leak
Have the 1995 H1, just has the heater/ac unit box rebuilt. I keep having a coolant leak running down behind the passenger foot board and the wheel well, running out the drain hole in the floor. Nothing from the unit box and of course it can't be seen from anywhere. All the hoses outside are not leaking along with the hoses running to the rear unit ase good as well. Any thoughts?
Old Nov 28, 2024 | 05:34 PM
Still sounds like the heater core
Old Dec 27, 2024 | 12:02 PM
Biggdadd58's Avatar
Got the previous leak fixed. Core tested good. Replaced all hoses with new but I believe the leak may have been coming from the heater core inlet was out of round. Once we fixed that, that leak stopped.
It now seems to be leaking from the left side engine mount, that is where the drips form. I know that fluid will pool when bleeding the system bit it never ends. I can see from underneath it doesn't seem to be coming from the water pump, nothing wet from there. If there is any helpful information as to where I can go from here, please respond.
Old Dec 27, 2024 | 02:21 PM
BLK WLF's Avatar
Couple of questions,
when you take the cap of the reservoir does air bubbles up from the hoses?
does it leak only when engine is on?
that said, not the after leaking.
Old Dec 28, 2024 | 08:48 AM
Biggdadd58's Avatar
No bubbles. The leak isn't one that pours out when running. It takes a while to accumulate from its source.
This was overnight with 10# pressure on the system. This will happen after running and letting it sit overnight as well.
Old Dec 28, 2024 | 09:42 AM
BLK WLF's Avatar
ok, looks brown to me, most coolants are green.
Indication of that color if it was green but turns brown is a bad headgasket.
It allows oil or exhaustair being mixed up and causing the leak at the head unit on the block.
Old Dec 28, 2024 | 10:10 AM
Biggdadd58's Avatar
The antifreeze that I put in is orange.
Old Dec 28, 2024 | 10:13 AM
BLK WLF's Avatar
Did you do a pressure test?
Old Dec 28, 2024 | 11:38 AM
Biggdadd58's Avatar
Yes I did. Put it to 11-12# for 3 days. Pressure held, no significant loss according to the gauge. This is what is baffling relating to the small amount of leakage.
ured_h3_vb
Oct 15, 2024 10:26 AM
JrBlanchard24
Aug 26, 2021 08:44 AM
Rockbox
Aug 25, 2011 05:54 PM
hummerray
Feb 15, 2009 05:51 AM
dizzy
Apr 22, 2008 09:34 PM
