Hummer Forums Help & Suggestion Center Need help with Hummer Forums? Have a suggestion to better HF? Tell us here!
Transfer case shifting help
Old Apr 2, 2026 | 12:35 PM
Duksrule's Avatar
Default Transfer case shifting help
Ok I picked up a 2003. When you go from 4 to 4lock or 4low it just blinks then goes back to 4. I replaced the switch, motor and transfer case control module. Yes I am putting it in neutral before trying to shift. I’ve gone forward and back and still nothing. I’m guessing with all major components swapped out that it’s something wiring related or even some safety features that are stopping the shift. Anyone have ideas?
Old Apr 2, 2026 | 02:15 PM
does the transfercase have enough oil? or maybe the shift fork inside the transfercase that connects to the selector motor is wore out
Old Apr 5, 2026 | 12:26 PM
Duksrule's Avatar
Default If you ta
If you remove the motor you can turn the shifter with a pair of pliers. It’s definitely electrical
Old Apr 5, 2026 | 04:17 PM
Scan all modules & post the codes.
PanchoH2
Feb 26, 2021 04:13 AM
happythree
Jun 25, 2015 10:33 PM
burnt orange hummer
Jul 29, 2013 01:39 PM
shkdwTthndr
Jan 4, 2012 07:28 PM
importkiller
29
Jan 15, 2008 02:51 AM
