Oxidized fender flares
1 Attachment(s)
I was having bad oxidation/dulling problems with my fender flares on my 06 H3. I tried rubbing compound and polish both with a machine polisher but to no avail. So I went with this:
Clay bar 2000 grit wet sand 3000 grit wet sand Fine cut cleaner with wool pad Rubbing compound with microfiber pad Machine glaze with soft foam pad Sealed it all in with a hard shell carnauba wax Turned out purty |
that turned out good... my rear fenders are sun faded and hoping i can bring them back to life.. The roof is also sun faded and tiny bubbles... Looking to wrap that as a temp fix... the FL heat and hummer paint don't seem to mix well....
Originally Posted by jerms212
(Post 318699)
Clay bar 2000 grit wet sand 3000 grit wet sand Fine cut cleaner with wool pad Rubbing compound with microfiber pad Machine glaze with soft foam pad Sealed it all in with a hard shell carnauba wax Turned out purty Congrats! I need to do mine but have never done something like that. Is it easy to mess it up worse? :confused: |
