Hummer is leaking oil bad
Old 01-29-2016, 01:48 PM
Kkneat's Avatar
Default Hummer is leaking oil bad
My Hummer h3 is leaking oil and I am wondering if anybody has any information on common areas where oil leaks occur both skid plate's are caked in oil on the bottom. I also have standing oil on the floor took it to local oil changing place they could not find or locate the leak any information would be helpful thanks
Old 01-29-2016, 01:56 PM
Kkneat's Avatar
Will be attaching pictures later tonight
Old 01-29-2016, 02:16 PM
Loose oil filter, oil fill plug, rear main, and oil lines to the remote filter location are all possible leak spots for the I5s.
To check for leaks the best way is to clean it first. Drop the front skid plate, go to the spray wash, first apply engine cleaner and let it sit, then spray clean so you can spot where it is originating from.
Old 01-30-2016, 08:40 AM
Also check the oil pan bolts. Sometimes they vibrate loose.
Old 01-30-2016, 12:29 PM
Kkneat's Avatar
Here's some of the pictures I was able to take, if anyone wants to take a look just follow the link. I think it's the oil lines where it is leaking from.
http://imgur.com/a/nQKKm
Old 01-30-2016, 05:38 PM
happythree's Avatar
id like to know more about oil lines? external??
as doc said ,spray clean. i did that with a leaky ford van,drove on ramps,blocked 4 wheels, locked park brake and went under with a good light and spotted a leaky pan gasket while it was running.
you gotta get it CLEAN first!!
Old 01-30-2016, 07:23 PM
Kkneat's Avatar
Will do, I'll post some pictures after I've cleaned it.
Old 02-06-2016, 03:39 PM
WR3NCHE4D's Avatar
Those are transmission cooler lines that are leaking. Repaired mine 2 weeks ago. Proper way to fix is new trans lines and new fittings at the rad and transmission, but I am cheap and just did a repair. Carefully cut the crimp off the line and peel off the crimp and install new rubber line with two hose clamps. Ta-dah! My lines were rusted out on the bottom of the rad. I would look there before cutting any crimps. I used a couple pieces of 3" GM trans line repair and one fitting on the rad. Could not separate the old line from the fitting.
Old 02-07-2016, 03:31 PM
zx1100's Avatar
Ours leaked at the trans lines going to the radiator also. Repaired if during the summer but now there is a leak again. Hopefully another quick fix.
drtom
01-17-2011 09:23 PM
hummer07
11-18-2008 10:46 AM
blackstangs281
38
04-04-2007 11:05 AM
jm4490
03-28-2007 12:16 PM
JoeBlowRacing
11-28-2005 05:51 PM
Quick Reply: Hummer is leaking oil bad
