Factory Monsoon wiring diagram?
Old 10-05-2007, 11:10 AM
96TL's Avatar
Default Factory Monsoon wiring diagram?
Does anyone have a diagram for the factory Monsoon amp in the rear? I'm wiring up an aftermarket amp, and need to know the positive and negative wires for the sub input, and I also need a switched 12V power wire. Thanks!
Old 10-05-2007, 01:15 PM
azz7772's Avatar
Default RE: Factory Monsoon wiring diagram?
i found this link that may or may not help you worth a try
http://www.ls1tech.com/forums/archiv....php/f-19.html
Old 10-05-2007, 01:18 PM
hilljob26's Avatar
dont cut the green...............it will go ..........BOOM....LOL
Old 10-05-2007, 01:20 PM
96TL's Avatar
azz7772, is there a particular thread you're referring to? Thanks!
Old 10-05-2007, 01:22 PM
mountainbiker's Avatar
Audio Amp C1
1-TN-Left Front Low Level Audio Signal (+)
2-D.GN-Left Front Low Level Audio Signal (-)
3-D.GN/WH-Left Rear Low Level Audio Signal (-)
4-BN-Left Rear Low Level Audio Signal (+)
5-OG-Radio Mute Signal
6-PK-Radio On Signal
7-Not Used
8-GY/BK-Remote Amp Sense Line Signal
9-OG/BK-Right Front Low Level Audio Signal (-) / D.BU in early models
10-L.GN-Right Front Low Level Audio Signal (+)
11-D.BU-Right Rear Low Level Audio Signal (+) / OG/BK in early models
12-BK-Right Rear Low Level Audio Signal (-)
13 to 16-Not Used
Audio Amp C2
1-BK-Left Front Tweeter Speaker Output (+)
2-YE-Left Front Tweeter Speaker Output (-)
3-L.GN-Right Front Tweeter Speaker Output (+)
4-PU-Right Front Tweeter Speaker Output (-)
5-YE-Left Rear Speaker Output (-)
6-BN-Left Rear Speaker Output (+)
7-L.BU-Right Rear Speaker Output (-)
8-D.BU-Left Rear Speaker Output (+)
9 to 12-Not Used
13-L.GN-Right Front Speaker Output (+)
14-D.GN-Right Front Speaker Output (-)
15-TN-Left Front Speaker Output (+)
16-GY-Left Front Speaker Output (-)
Audio Amp C3
1-OG-Battery Positive Voltage
2-BK/WH-Ground
3-D.BU/WH-Left Subwoofer Speaker Output (+)
4-L.GN/BK-Left Subwoofer Speaker Output (-)
5 to 6-Not Used
7-L.BU/BK-Right Subwoofer Speaker Output (-)
8-L.BU/BK-Right Subwoofer Speaker Output (+)
On the radio should be a 24-pin connector (2-rows (A and B) of 12)
B1-OG-Battery Positive Voltage [I believe this is constant and not switched]
B3-PK-Radio On Signal (not 12v)
B6-OG-Radio Mute Signal (not 12v)
Old 10-05-2007, 01:41 PM
96TL's Avatar
Thanks mountainbiker! I really appreciate it!
Old 10-05-2007, 01:45 PM
96TL's Avatar
Are there there 3 seperate amps, or just 3 different plugs?
Old 10-05-2007, 03:44 PM
Most likely you have C1 going from your head unit to the amp and C2 leaving your amp out to the speakers.
Old 10-05-2007, 10:08 PM
don't use the factory power and ground wires for a new amp!!!!! They are too small of a gauge wire and will limit your new amp.
Old 10-08-2007, 07:09 PM
96TL's Avatar
importkiller, I'm not. I just need to wire up an LOC to the Monsoon amp signal wires. Does anyone know an easy remote turn on wire I can tap? Thanks.
Quick Reply: Factory Monsoon wiring diagram?
