Thermostat 186F but engine at 210F?
Old 08-12-2015, 09:15 AM
Hummerrican's Avatar
Default Thermostat 186F but engine at 210F?
Any could explain why H2's use 187F thermostat but the engine normal temp is 210F???
Can I install a 160F thermostat or a bigger radiator is a better idea?
Old 08-12-2015, 04:15 PM
yoymon's Avatar
first 210 is just fine, supposed to run 200-210, havent hooked scanner to my h2 yet but i found on other gm's temp guage read a few degrees higher than scanner said
Old 08-12-2015, 08:07 PM
The thermostat temp is just so you can determine when it will begin to open to allow coolant to circulate from the radiator into the motor through the T Stat. Most common T Stats will not be completely open to allow full flow until appx. 15-20F above their rated temp. So, add 20F to your 187F T stat and you get 207F, I'd say working exactly like it is supposed to.
Moving to a lower temp T stat just slows down how quick your motor reaches full operating temp, then places more cooling burden on the radiator. Modern GM vehicles were designed to run at a sweet spot of 195-215F (depending upon model) for emissions efficiency as well.
Old 09-02-2015, 08:28 AM
Update...
Recently the 160F thermostat was installed with new GM coolant. During normal driving the engine temp was less than 180F. As soon the A/C was on, the engine temp goes to 197F sometimes 200F. But when the A/C was turn off it return to the 180F range.
kmleong
09-02-2015 08:40 AM
jandmtv
06-02-2011 06:17 PM
c3 rolling
01-23-2009 06:30 PM
veves
05-31-2008 09:34 PM
faceman13
12-02-2007 08:16 PM
Quick Reply: Thermostat 186F but engine at 210F?
