Ignition Coil Needs Replaced
Old 08-21-2016, 02:05 PM
K0PIR's Avatar
Default Ignition Coil Needs Replaced
I need to replace an ignition coil. I had a P0305, swapped coil with #4 and now I get P0304.
I have already cleaned the TB and MAF sensor. New AC plugs last year and the plugs looked fine when I swapped the coils.
I'm pretty sure these are the original coils. It's a 2006 with 175,000. Should I replace all 5 or just the bad one?
What are you replacing these with? The ACDelco are very expensive and I see some cheap one's on Amazon for a whole lot less. I'm looking at ENA set of 5 for $72.99. Or I can get one PT Auto Warehouse brand for $24.50.
Any recommendations?
Thanks!
Old 08-22-2016, 09:59 AM
I would do the AC Delco coil and I would replace the one that is bad. The other four could go for years without having any problem, or they could puke tomorrow? I would never skimp on ignition parts.
My Grandfather always liked to say: start with the easy stuff, and never fix what ain't broke.
Good luck.
Old 08-22-2016, 11:33 AM
K0PIR's Avatar
Yeah I found an ACDelco for $51 and I'll get it. The first couple of searches they showed up for over $100.
Thanks!
Old 08-23-2016, 03:28 PM
Bunger's Avatar
AC Delco coil on Rockauto is under $26
https://www.rockauto.com/en/catalog/...tion+coil,7060
Old 08-24-2016, 06:44 AM
K0PIR's Avatar
Those are good prices, thanks Bunger.
Hummer_SG
10-19-2012 11:09 PM
Autopilot
07-20-2012 09:13 PM
Hummer_SG
05-25-2011 12:40 PM
madmaxmyers
05-16-2008 09:53 AM
cagef15
09-29-2007 09:16 AM
Quick Reply: Ignition Coil Needs Replaced
