180 Degree Thermostat
Old 09-28-2010, 12:29 AM
kmleong's Avatar
Question 180 Degree Thermostat
I have replaced my factory thermostat with a 186 degree Thermostat. My temperature gauge still reads just shy of 210. Do you think it would make a difference to change to a 180? Would it be too cold for winter? Vancouver,B.C. 0-5 degrees. Opinions???
Old 09-28-2010, 07:37 AM
DTS62284's Avatar
Do you have a programmer for your vehicle, if so did you re-tune the fans to come on sooner?
Old 09-30-2010, 08:19 AM
calif phil's Avatar
2004 has a mechanical fan clutch so there is no way to reprogram them to come on sooner.
The thermostat sets the min operating temp not the maximum temp. I would bet you have a plugged or partially plugged radiator. You can try and flush it to see if that will help. Your truck should have a 195 degree thermostat. A 180 degree stat will still provide plenty of heat for winter.
Old 10-01-2010, 07:26 AM
kmleong's Avatar
Thanks to all for the advice. I switched to electric fans and supposedly had my predator to set the temp at 186 on a custom tune. Still reading shy of 210. There was another thread somewhere about a plugged return nipple to the expansion tank or something like that. Going to take your advice and reverse flush my rad and new coolant.
Old 10-01-2010, 09:53 AM
calif phil's Avatar
DUH I should have read your sig. and seen you had Electric fans.
Old 03-18-2012, 02:24 AM
craneop's Avatar
Question Same problem here!
purchased the 03 and noticed just shy of 210deg. changed to a 180 with a full system drain. all fluid looked great. no leakes anywhere. refilled system and still @ 209deg. any ideas please?
Old 03-19-2012, 11:37 PM
2wheelmonster's Avatar
maybe your putting in the wrong type of radiator fluid? orange vs. green
Old 03-20-2012, 01:17 AM
LoJac963's Avatar
210 is right in the middle or the gauge no? Isn't that about perfect?? If its just shy of the 210 mark I don't understand what the big deal is especially if there are no overheating issues. A few degrees before the mark on the gauge isn't going to change anything-it could even be the temp sensor.
Old 03-20-2012, 08:53 PM
bflorin's Avatar
Those gm temp gauges are basically enhanced idiot lights. I havn't personally had an accurate temp gauge in a GM vehicle since 1998, but I dont have anything newer than 2004. The ECM does read an accurate temp. I just plug in my scan tool if I want to check out whats really going on.
Old 08-16-2015, 08:03 AM
Hummerrican's Avatar
Hi to all.
Verify your cluster readings (stepper motors).
My H2 was reading 210C even higher with 197C thermostat. After a new set of stepper motors installed, engine the temp reading was exactly 197C. The trans temp was reading 150 and 160C (obviously with a bigger oil cooler), and now read 140-150C.
Just my 2 cents.
Quick Reply: 180 Degree Thermostat
