Largest tire/wheel on an 08?
Old 05-27-2009, 09:36 AM
SD90's Avatar
Default Largest tire/wheel on an 08?
What is the largest tire size I can get on an 08 H2 without a lift and without rubbing?
Old 05-27-2009, 11:11 PM
Circuitguy's Avatar
Its the same for all H2's 03 thru 09. Anyting above a 35" will tend to rub depending on the wheel offset you choose. Most popular are 20" wheel with a 325/60/20 tire or a 22" wheel with a 325/50/22 tire.
Old 05-28-2009, 04:30 PM
bflorin's Avatar
I can tell you 37's w/ 20mm offset are not even close to fitting....
****..now I need to buy a lift...
Old 06-04-2009, 08:00 PM
Quijy's Avatar
I have 35s, they fit fine.
Old 06-05-2009, 07:19 PM
fcfanatic's Avatar
I like 20" we also have them on the BMW carswe have in the X5
They look the nuts and the price of the tyres are better.
Old 06-06-2009, 03:34 PM
pteam's Avatar
35's are the size of the standard hummer rims and tires I believe.
Old 06-08-2009, 09:20 PM
HumminNBoatin's Avatar
37x12.5x17 BFGoodrich tires KO's or KM2's fit on stock rims without issues at all. Only rubbing is on the swaybar causing no damage to tire or truck. Its when you go to a wider tire that you start having the rubbing issues. I had the BGF KM's in a 37" size with no problems. I now have the Toyo M/T and they are 13.5 wide They rubbed untill I did a slight lift.
So the answer to this question is Yes you can fit a 37x12.5x(what ever wheel size you want) "mine are 18's" without rubbing issues.
Andreas_Sweden
02-02-2013 09:03 AM
jsbihn
03-22-2012 05:44 PM
Landbruiser69
01-07-2011 02:49 AM
Nxsov180db
06-02-2008 01:38 PM
inked
25
06-03-2006 10:15 PM
Quick Reply: Largest tire/wheel on an 08?
