service tpm ?
Old 12-15-2006, 07:39 PM
jm4490's Avatar
Default service tpm ?
Driving today about 25-30mi into my trip on the highway "serv tpm" message came up on the dash stoped at a gas station for 5-10 min started truck message was gone..did some more city driving stayed off the whole time ,got back on the highway and roughly the same time/distance into my trip the message came up on the dash "serv tpm" the truck has been sitting about 20-30 min now since i got home and the message is still on .. Any thoughts?
Old 12-15-2006, 08:40 PM
Default RE: service tpm ?
Dealer will have to replace the TPM (Tire Pressure Monitor) module...Nuttin to it!
Old 12-15-2006, 09:57 PM
simian's Avatar
Now if one were to rotate the tires dont you have to "reset" the tpm?
Old 12-15-2006, 10:35 PM
Yes..but all you get is the tire icon to light up, I think
Old 12-15-2006, 10:55 PM
check the tire pressure in all 4 tires
Old 12-15-2006, 11:54 PM
jm4490's Avatar
Just checked tire pressure and the tires range from 31-34 psi thinking about bumping that up another 5 psi...bring them up to 38-40..the tires are 285/75/16
Old 12-16-2006, 12:21 AM
Maybe that's all it is then, let us know if the proper tire inflation cured your alarm..
I have the same tires as you, and I always maintain 40 PSI cold in all four, the tires can Handle 50 PSI MAX..(best to keep then all equal too.)
Old 12-16-2006, 12:47 AM
jm4490's Avatar
I just put on Bridgstone dueler at revo they have a max pressure 65psi...that should be good right!! or should i keep it at 60ish!!
JUST KIDDING!!
Old 12-16-2006, 12:51 AM
the serv. tpm is the message you get for low air inflation, no major deal and nothing to worry about...nuttin is broke. You will get the message at each ignition cycle, just hit the trip odometer button once and the message will go off and not reappear until the next ignition cycle. The entire TPS system that GM developed is a waste of time and money, I haven't even had the sensors for three months now and only got the message one time.
Old 12-16-2006, 12:55 AM
Yeah Mike, that's because you carry around your stock tires piled in the back..
Quick Reply: service tpm ?
