Oil Change light
Old 09-12-2007, 02:19 PM
2L8IWON's Avatar
Default Oil Change light
Once you change to oil how do you get the oil change light to turn off? I am in England with no dealers anywhere close to me. Your help would be greatly appreciated.
- Jesse
Old 09-12-2007, 02:47 PM
Default RE: Oil Change light
GM Oil Life System - Resetting
The vehicle has a computer system that has a change engine oil light, indicating when to change the engine oil and filter. This is based on engine revolutions and engine temperature, and not on mileage. Based on driving conditions, the mileage at which an oil change will be indicated can vary considerably. For the oil life system to work properly, the system must be reset every time the oil is changed.
When the system has calculated that oil life has been diminished, it will indicate that an oil change is necessary. The change engine oil light will come on. The oil must be changed as soon as possible. It is possible that, if the vehicle is driven under the best conditions, the oil life system may not indicate that an oil change is necessary for over a year. However, the engine oil and filter must be changed at least once a year and at this time the system must be reset. If the system is ever reset accidentally, the oil must be changed at 3,000 miles (5 000 km) since the last oil change. Remember to reset the oil life system whenever the oil and filter is changed.
1. Turn the ignition to RUN with the engine OFF.
2. Press and release the reset button in the driver information center (DIC) until the OIL LIFE message is displayed.
3. Once the alternating OIL LIFE and RESET messages appear on the DIC display, press and hold the reset stem until several beeps sound. This confirms the OIL LIFE system has been reset.
4. Turn the key to lock. If the CHANGE OIL message comes back on when you start the engine, the ENGINE OIL LIFE system has not reset. Repeat the procedure
Old 09-12-2007, 02:48 PM
Hope this works!!!
Old 09-12-2007, 03:08 PM
RTFM that's how I found out how to reset mine.
Old 09-12-2007, 04:21 PM
Bob has it right....listen to the bling master he is all knowing!!!
Maybe he bought it used and didn't get a FM....how's he supposed to read it then? Or maybe he's like me andhis 3 year old decided to throw it into the toilet...there's no RFTM for me anymore
Old 09-13-2007, 06:17 AM
hilljob26's Avatar
ITS ALWAYS EASIER TO ASK THESE GUYS,THEY ARE HUMMER GODS
Old 09-13-2007, 09:21 AM
RTFOM [8D] F5fstop posted the 06 H3 Owners Manual online to view by all http://www.hummeranswers.com/ No excuses now!!
Old 09-13-2007, 02:53 PM
is that "read the f'in online manual"?
thats funny!!!
Old 09-13-2007, 03:13 PM
Yes sir, it is!
rhill20
07-01-2013 12:23 PM
drtom
01-17-2011 09:23 PM
Bo
16
10-09-2010 08:44 PM
hummer07
11-18-2008 10:46 AM
machines
02-24-2008 11:57 AM
Quick Reply: Oil Change light
