Losing Antifreeze
Old 12-25-2006, 12:45 PM
CruisinCarAudio's Avatar
Default Losing Antifreeze
I Have 20k miles on my h3, and have had to add a quart of antifreeze on 3 separate occasions, the first time, when it was a week old, this last oil change i had residue on the oil cap. does this mean its blowing in on one of the seals. Thanks Jason
Old 12-25-2006, 01:13 PM
Default RE: Losing Antifreeze
Sounds like a head gasket problem[:@]
Old 12-25-2006, 01:15 PM
blackstangs281's Avatar
Could be the start of a head gasket problem. I would have a pressure check on each cylinder done. That should let you know if you have a small gasket leak.
Old 12-25-2006, 02:13 PM
One other thing..Change your oil right now or get it to the dealers immediately..Because water /coolant in the oil will destroy the engine soon..
Old 12-27-2006, 12:59 AM
its a very slow leak, it was down a quart when i picked it up, didnt think anything of it just filled it, but had to add 2 quarts in the last 20k miles, I just changed my oil last week, I am trading it in tommorrow, for a 07 H2 so its the dealers problem now,
Old 12-27-2006, 01:19 AM
Good for you and good luck..will this be the wife's replacement for the H3..?
Old 12-28-2006, 12:55 AM
yeah, its my wifes replacement for the h3, pics coming soon, picked it up today,
Old 12-28-2006, 05:37 PM
fisherman119's Avatar
I had a heater core go bad. Mind leaked on the inside but I was told most leak outside????
Old 12-28-2006, 08:29 PM
They say that because they normaly leak into a tray that has an outlet through the firewall.
Old 12-28-2006, 09:48 PM
Chris beat me to it....A lot of times, core leaks go unnoticed for a while besides the strong smell of coolant,because it (the coolant) drips out the A/C condesate drain pipe beneath the car.
Quick Reply: Losing Antifreeze
