Locking Fuel Door that doesn't require drilling into the body?
Old 03-04-2008, 07:28 PM
dmurdock's Avatar
Default Locking Fuel Door that doesn't require drilling into the body?
I'm looking for a black locking fuel door that doesn't require drilling into the body. I have found tons of fuel doors but they all say "easy install in minutes" which frankly scares the crap out of me [:-]
Old 03-04-2008, 07:36 PM
blackbear's Avatar
Default RE: Locking Fuel Door that doesn't require drilling into the body?
Nothing that a I know of, it took me less then 20 mins to install mine, it comes with a template that you tape on and just drill the holes, not hard to install.
Old 03-04-2008, 08:16 PM
Gunner_45's Avatar
I have this one..........(in chrome)....and it has held up very well.
http://www.realwheelsacc.com/h3_202-2-bp.html
You can get it from any of the vendors here on the forum.
Uses 3m tape and two self tapping screws to secure it to the fuel filler bucket.
I had it on my '06 then transferred it to my '07, bucket and all.
If you had to take it off, you would be left with only two very small holes on the inside of the bucket and some tape residue.
Old 03-04-2008, 09:01 PM
dmurdock's Avatar
ORIGINAL: Gunner_45
EXACTLY what I was looking for..thanks!!!!!!!!!!!!!!!!!!
Old 03-05-2008, 01:32 AM
bonzaiii's Avatar
I don't suppose yu like to give a little tutoril. Sounds like my install is gonna be the same but not sure what needs to be removed and how in order to get in and put the screws in.
Old 03-05-2008, 11:49 PM
Gunner_45's Avatar
Super simple install.....15 minutes tops and 10 of that will be cleaning off the plastic bucket so the 3M tape will stick.
Instructions and self tapping screws come with the door. All you need is a screwdriver...Medium Phillips Head.
Clean the bucket/trim ring, position the door, peel off the tape and stick that bad boy on. There are two tabs in the
backside of the door ring that will attach to the inside of the bucket that keeps everything nice and snug.
No drilling, just push and screw.
That's it.
One word of advice, unless you trust yourself to eye ball it, I'd test position the door then use a crayon to mark the sweet spot.
You only have one shot with that tape.
Old 03-06-2008, 09:38 AM
bonzaiii's Avatar
Thanks Gunner, mine came with the door, three small L brackets, 3 self tapping screws and NO instructions. I'm gonna install it later this morning when it warms up a bit.
Old 03-06-2008, 10:21 AM
branstone's Avatar
wow $200 for a fuel cap???? but it does look nice
Old 03-06-2008, 12:01 PM
CWS's Avatar
CWS
CWS is offline
ORIGINAL: branstone
Hey......that tape is expensive ! [sm=bangbang.gif]
Old 03-06-2008, 01:14 PM
anyone try these from ebay..>
http://cgi.ebay.com/ebaymotors/04-08...spagenameZWD1V
Quick Reply: Locking Fuel Door that doesn't require drilling into the body?
