Horn Replacement Help
Old 02-11-2012, 08:45 AM
Baldturtle's Avatar
Default Horn Replacement Help
My factory horn has stopped working. Before I go get a replacement, I was wondering if their is something else I should check for like a blown fuse?
If so, any assistance with where to look for the problem would be appreciated.
On the other hand, if I do just need to replace the horn, help with where it is located / removal instructions would be great as well.
Thanks!
Old 02-11-2012, 09:08 AM
nijoma's Avatar
Default I would like to know also
The horn is weak but an air horn requires a compressor, is there an aftermarket that's bolts in without to many additional parts with more sound?
Old 02-11-2012, 11:01 AM
wfturner's Avatar
I upgraded to dual (high/low) electric horns and they sound great and NO relay
This link is from another forum
Wolo Bad Boy Compact Air Horn, Model# 419 | Air Horns + Sirens | Northern Tool + Equipment
And you should install a relay tied to directly the battery for this air horn setup
Old 02-11-2012, 11:28 AM
DAGKANA's Avatar
the stock horn is located behind the chrome upper grille assembly, fairly easy to get too... 4 bolts and some plastic tabs. It has a spider nut on the back side a 10mm wrench will take it off... however there IS a fuse... so you could check that first, its in the owners manual so just quickly thumb through that and scoot over to your closest auto parts store... when you pull the fuse look closely at the inside, there is a small metal filament that if broken/burnt means the fuse is the culprit...
dbruno94
11-01-2013 09:17 PM
Alex2012
07-11-2012 12:57 PM
TSLevin95
10-08-2011 09:12 PM
swr930porsche
03-25-2011 10:40 PM
CerberusSVT
25
06-12-2010 12:29 PM
Quick Reply: Horn Replacement Help
