H3 stalling
H3 stalling
My hummer H3 has been acting weird for the past month. When I'm driving pressing the gas not flooring it just steady speed I feel the rpm's go up and down. Not a huge feeling but you can feel it! I went to a shop and they said to start by cleaning the fuel injector system, it was a 3 part cleaning service he said they did. Went to pick it up and seemed like it helped but nope it came back, it seems like its not as bad but I have only put on a few miles. There is no check engine light on, called onstar and nothing came up for them. Any one have any ideas or have had this problem??? When I come to a stop it does not do it, only when im driving. Last thing I want to do is just keep taking it back and play a guessing game and keep spending more and more money. I asked if it could be the spark plugs but the mechanic said that he didnt think it would be that since i had no check engine light on.
Thanks guys
Thanks guys
Just a guess but try looking at your throttle body, if dirty pull of and clean with throttle body cleaner. When you remove flexible hose you should be able to see if it is clean or not also open throttle plate it is usually dirtier on back side
Thanks guys
Thanks guys
Also, Clean the MAF sensor. GL
rtwash
12-13-2013 10:45 PM
rtwash
04-02-2008 03:36 PM
jameswhite
08-23-2006 10:15 PM
