H3 need help for sizing 20" with 35" tire
Old 01-26-2011, 10:09 PM
catchmes2000's Avatar
Originally Posted by Draketh
He probably didn't measure from center of the hub. If the back was that high and he didn't mess with it then he sure didn't measure from the right spot. I dunno.
Hey i mesure from the middle of the rim were the H of hummer in the center cap to the under the fender. before and after!!!! this is the best place to get a accurate reading.
Jeff
Old 01-26-2011, 10:20 PM
Tainter are you sure they don't need to be leveled? Most everyone I've seen has a leveled truck if they have 35's. As a matter of fact the biggest reason I see people level their trucks is to go with 35's.
Now I'm just confused as I was planning on going 35's soon.
We have had 4 differnet H3/H3Ts, Yep I'm sure. Actually if you DO NOT level the front you will have less scrub against the sway bar than if you do level it. However, both of our current HUMMERs have been mildly leveled 23 1/4" to gain a little bit more breakover angle (we wheel them).
Old 01-27-2011, 06:03 PM
bump
Old 01-31-2011, 06:38 PM
If anybody has pick of hummer with 35" tire please post pic.
Thanks Jeff
Old 01-31-2011, 07:37 PM
mbone20's Avatar
Do you need to buy the leveling kit for this set up? What kind of kit did you get?
Old 02-01-2011, 12:13 AM
Read post #4 and #12 of this thread and you can do a SEARCH for "leveling" or "torsion bar crank" or " cranking tbars" etc. There are prob 50+ threads on this subject.
Old 02-01-2011, 07:21 AM
Hey i install a radylift system on mine and did have any issue's about 1 1/2 to install and need a alignment after.
Jeff
Old 02-01-2011, 11:28 AM
largemouthbass's Avatar
One more time for those that do not want to believe Tainter....
you do not need to level an H3 to fit 35's
you do not need a leveling kit.... there is plenty of room to turn your tbars up. WASTE OF MONEY!
USE THE SEARCH FEATURE ON HERE OR GOOGLE!! there are a billion pics of H3's with 35's
Old 02-02-2011, 09:37 PM
Bullwheel's Avatar
Default Offset...10 or 35?
Originally Posted by catchmes2000
Hi i contact the guy who one's this hummer he told me they were 20x8.5" but dosint know the offset... but wen i look up the tire 35x12.5x20" Nitto Trail Grappler it will fit on a 8.5" rim to a 11" rim but but best fitment is 10", i know you can get these wheel's in 10" and that what they recommend for the size of tire... the only thing i am not sure is that maby you have to go with a 20x8.5" because the off set on the 20x10" is maby too mutch... Can anybody help me with this desition...
Thanks Jeff
It would be great to know if he uses the 35mm offset ....somehow it looks like....?!
These rims also come in 10mm offset....one inch more outside....makes some difference...
Actually rim shops say that the 10mm offset version fit the H3 fine....but is it also the case with 35" tires?
The H3 on the photo looks just fine....but my H3 has the fender flares...and I cannot remove them as there are holes drilled.....shXX... so for me the ET 10 would fit better....if it not tears of the fenders and flares after the first bump in the street...
Old 02-07-2011, 08:47 PM
bump
Quick Reply: H3 need help for sizing 20" with 35" tire
