Differential leak H3
I have a 2008 H3 and I have noticed leaking from the rear differential. There is always a little drop hanging from it and sometimes a drop on the driveway. I thought it was the drain plug leaking but the mechanic said it was tight. They recommend I do a differential rebuild, basically replacing all the seals, for $400. Is there an easier way around this?
I had a similar leak and it was the front dif pinion seal and it was changed by the dealer for less than half what you mentioned.
All it takes is a $10.00 seal, 1 hour with the proper tools, and a couple of beers. Don't forget to get some 75w90 GL-5 (synthetic) diff fluid to top off, or if you haven't done in awhile, diff fluid change. GL
