2006 H3 Stereo Upgrade
I have a 2006 Silver Base model with manual tranny.
It has onstar, etc.
What is the adapter that I need to install an aftermarket stereo? I have a double-din Pioneer that is collecting dust right now. Please let me know the best price as well.
Also, that fake antenna on the top right of the vehicle, can that be used for XM from my Pioneer?
It has onstar, etc.
2003 2004 2005 2006 Chevrolet SSR Bose OnStar Adapter | eBay
Do I really need one of these? I do not use onstar and this model vehicle does not have bluetooth or XM.
My aftermarket stereo is a Pioneer DVD and has XM service.
Radio upgrade H3
I have installed my Kenwood touchscreen in my 07 H3 with no problems. It's time consuming though. You need to get the adaptor from your local stereo shop or on ebay. Make sure it is vehicle specific. It will allow you to keep your onstar, door chimes thru your speakers etc. they run around $100+ I found mine on ebay for $60 shipped. Just type in on ebay what you are looking for and they should pop up. I believe they are called axxess and are made for Gm vehicles. Make sure it is the one that will keep all of your chimes working. They have ones with and without. Again they are vehicle specific.
It's pretty much like screwing in a light bulb, no rocket science to it.
Go to Crutchfield or some other on line audio supply house and research what you need for what you are trying to do.
I had a feeling that without the adapter, like the axxess mentioned above, I would kick CE lights OR as Windy pointed out, if I do not get the adapter I will not have door chimes or warning indicators.
Final question, it appears that most of these adapters come with a type of wiring harness, so no separate harness will be required for the install, correct?
I do not use onstar.
Windycitykid:
Will this work?
Radio Wire Harness Interface Aftermarket Stereo Installation Axxess LC GMRC 01 | eBay
Also, do I need a double-din adapter to mount the stereo? It's a double-din deck and looks like it will be a tight fit.
Will this work?
