Domo light not working
Old 05-16-2016, 10:58 AM
OCFDfyrfytr's Avatar
Default Dome light not working
Domelight does not work, nor door panel lights, when any of the four doors are open on 2009 H2. Map lights work correctly. I can rotate manual override button/dim button and manually illuminate all lights in question. Again no interior lights come on when Any door is opened. Override button working when rotated to turn dome lights on.
Old 05-22-2016, 05:02 PM
HUMTECH's Avatar
Is the dome lamp defeat button on? This button disables dome lamps when doors are opened.
Old 05-23-2016, 10:22 AM
Default Some light not working
Sir I believe according to the manual the button I depresses then extends, the one I rotate to manually turn lights on, is one in the same? If so yes. This button to right of headlight switch.
Thanks for helping
the dome lamp defeat button on? This button disables dome lamps when doors are opened.[/QUOTE]
Old 05-23-2016, 12:42 PM
HUMTECH's Avatar
push the push button to the left of headlamp switch Domo light not working-h2headlight.jpg
Old 05-27-2016, 10:28 PM
madmike's Avatar
Banned
Alright folks. Was wiring up a aftermarket map light splicing into my map lights. I lost my map light orange wire power. White wire power (when doors open and or light wheel is turned all the way up) works fine. Anyone know the fuse the orange wire goes to? Does it go to the Body Control Module? I can't find a schematic anywhere. Thanks in advance.
Not so Mad Mike
Old 05-28-2016, 01:26 AM
HUMTECH's Avatar
The orange wire is a BCM controlled circuit. check all the tbc fuses in left ip panel fuse block.
Old 05-28-2016, 01:57 PM
madmike's Avatar
Banned
They did look fine but I should do an ohm's check for fuse continuity. Thanks tech dude!
TxHummer07
03-22-2015 11:02 AM
JensH2
12-14-2013 02:27 PM
JonnyD
08-06-2013 05:12 PM
Garland417
03-01-2007 03:51 PM
HummerGuy
10-05-2006 09:11 AM
Quick Reply: Domo light not working
