Shift grenade
I'm having the same issue. Damn thing never gets set properly. Key gets stuck in ignition. What advice do you have?
Apologies, I can't easily take a picture of the bit you need to see, and I'm sure you know what the external grenade looks like.
Astro did you ever resolve your mounting issue?
I had to remove mine to install a Pioneer AVIC-F77DAB radio system. On mine there was a small T15 Torx screw at the very front which mated with a hole in the shaft. Its a bit tricky to align but essentially the screw winds into the hole rather than binding to the shaft.
