Severe vibration in 2005 H2
Old 01-24-2012, 06:48 PM
Flyplanes5's Avatar
Default Severe vibration in 2005 H2
I have a 2005 H2 with 75K miles. While driving under a load, I get a severe vibration which seems to be coming from the front wheels. I thought it was a U-Joint and I have since check all U-Joints and CV joints. Nothing seems loose and all joints seem tight. Does anyone have any recommendations before I head to a shop??
Thanks!
Old 01-24-2012, 07:22 PM
Caraddict's Avatar
Ball joint,hub bearing?
Old 01-25-2012, 09:27 AM
Flyplanes5's Avatar
If I have a bad hub bearing, when I jack the wheels up would I have some slop if I grab and pull on the tire?
Old 01-25-2012, 11:38 AM
mfish's Avatar
Yes you will have slop if its your hubs, it may also be your pitman and/or idler arm
Old 05-04-2013, 09:47 PM
man-of-war's Avatar
Default 2008 Vibration @ Low RPM
I took the Hummer to have it safetied and got it back with a vibration when reversing or driving foward @ around 1000 rpm but goes away when speed increases.
The mechanic I took it to would seem not to like Hummers seeing all he talked about was if I had 2 jobs to pay for gas
I don't want to go ask him If by chance he forgot to put something back and the wheels fall off.
08H3
05-27-2008 08:43 AM
Ghostrider
18
08-28-2007 08:31 AM
tteazis
05-06-2007 10:13 AM
crank
16
08-02-2006 04:06 PM
G Man
02-25-2006 05:58 PM
Quick Reply: Severe vibration in 2005 H2
