Lowered back to stock help
Old 12-23-2008, 12:16 AM
Trainnwhls's Avatar
Default Lowered back to stock help
Hi
I have a 05 h2 that the previous owner lowered. I was told torsion keys for the front and i need to adjust the air ride shock mounts for the rear. does anyone know how to go about this, and how much? Id like to get it back to the stock. thank you for any help you can give me.
Old 12-30-2008, 10:32 AM
Default RE: Lowered back to stock help
well if your doing the job yourself it wont cost very much. this is my suggestion. if you have aftermarket torsion bar keys, you need to get stock ones. I would recommend going to a truck acc. shop and see if they have some stock torsion bar keys (most do cause they do leveling kits all the time). Ask them if you can buy them. the rear should be just lowered by the arm that is on the driver side. If you get a shop to do this I wouldnt pay more than $300 for this job.
Old 12-30-2008, 04:54 PM
Trainnwhls's Avatar
I thought the two bars on the front are for the left and right sides and the rear air ride is seperate. If i change the keys on the front how do i get the air ride to stock hight. do i have to relocate a sensor?
Old 01-02-2009, 01:57 PM
you are correct the two torsion bars are for the front. what the people probably did was put different torsion bar keys to lower the front. as for the rear there is a height sensor in the driver side rear fender well. that was probably adjusted. that is most likely what they modified to lower the rear.you can probably look at it and tell what they did.
Old 01-02-2009, 10:52 PM
Trainnwhls's Avatar
thanks for all the help. il let you know what i find out when i get a chance to look at it.
Old 01-19-2009, 07:10 PM
Trainnwhls's Avatar
So I turned the front torsion bars up and i like it with the air lift on but if i take the 2 inch air off its lower in the rear. how can i get the rear back to stock height. where is the sensor for the compressor to level it. any help and or pics would help a ton. thanks
BummerHummer
11-13-2012 06:54 AM
wet_rat
05-24-2010 07:26 PM
H3Tex
06-01-2009 02:13 PM
ludwig75
38
07-18-2008 03:42 PM
Dunwitu
08-01-2007 04:45 PM
Quick Reply: Lowered back to stock help
