Just bought H2 -notice it doesnt stay in 4H, sometimes goes to N
I've never seen one go into N.... maybe an encoder motor...
FWIW, IMHO, after only 2 weeks of ownership and you have 3 major issues, including a CEI...
I would drive that back to the dealer and demand it repaired, and if not, I would hire an attorney.
The major issues you are having are clearly not normal wear and tear and clearly are not items that could have gone unnoticed by ANY person, trained in automotive repair or not.
I would also recommend that you visit your dealer. I can also look into this issue further. In order to do more research, I will need some more specific information from you such as your name, address, phone number, the VIN for the vehicle, current mileage, and dealer name. If you have further questions, please feel free to contact me either on the thread or via private message. Thank you.
Tricia, GM Customer Service.
You can find your own local HUMMER certified dealer without giving Peggy any information. hummer.com and click on the "service" tab.
even for my hummer also this problem occurs.
sometime wen i start my car, the Red Neutral Light is ON..then while driving i have to press 4HI and then Yellow 4HI light is ON...
and this occurs almost daily.i couldn't figure out the problem!!!
while Red Neutral Light is ON i can drive the car even at 170km/h(i tested)
I had the same thing happen at around 89,000 miles.
I had the same thing happen and replaced the Transfer case motor for about $170. I did it myself took about 20 minutes. had the transfer case flushed just as a precaution afterwards at a local shop.
Thanks, Ryan
If you don't believe me just start a thread and ask if GMCustomerService Tricia/Peggy has EVER been able to help ANYONE.
