Help needed,electric short and fire!
Old 09-05-2014, 08:29 AM
calif phil's Avatar
The airbox vent will pop straight off. There are clips that hold it tight. I use a plastic tool to get underneath it and lift it off.
  #22
Old 09-05-2014, 01:44 PM
S Reynold Gudam's Avatar
ok will try it that way
  #23
Old 09-07-2014, 11:42 AM
hi all. can anyone please share with me of which fuse relay underhood box set macthing with H2 from any GM TRUCK? it is much easier if campatibility is there,at least i got an option. aLSO I'm tryin to note down all the relays and fuse in the said box ( amp/rating,etc). I seen a pic but it is not very clear on the amp/rating specs.
thanks
  #24
Old 09-09-2014, 11:45 AM
HELLO ALL,
Update.
Hood finally opened. Luckily the hood cable still intact. I removed the plastic lever and pull the steel cable with plier. A bit tough at the beginning but after a few tryout finally it opened,THANKS GOD!!! Now I have to clean all the mesh and access all the damage parts.
  #25
Old 09-11-2014, 01:44 PM
Need opinion...
Is 07 underhood fuse box is same with 04? I found 1 in ebay but it 07.
thanks
  #26
Old 09-11-2014, 02:02 PM
Pics after dismantling. Headache!!!!
Attached Thumbnails Help needed,electric short and fire!-20140911_185711.jpg   Help needed,electric short and fire!-20140911_185428.jpg   Help needed,electric short and fire!-20140911_185727.jpg
  #27
Old 09-11-2014, 03:50 PM
ak47dennis's Avatar
Originally Posted by S Reynold Gudam
Need opinion...
thanks
I would go to the dealer and have him look up the part for your 04 then look up the same part for 07.
You will end up with another fire on your hands if you dont it exactly right.
  #28
Old 09-11-2014, 04:54 PM
you are absolutely right but i just wanna comfirm either the 07 can be fitted into 04. My car in service garage now and i just wanna try to look for used parts. The garage will also look for used parts also the new parts. I will decide later base on the price quote and off course the correct fitment.
  #29
Old 09-12-2014, 08:29 AM
calif phil's Avatar
I take it you had no full coverage insurance and the cost is out of your pocket?
  #30
Old 09-12-2014, 08:50 AM
armywrx's Avatar
Any ideas what caused it after diving in?
Quick Reply: Help needed,electric short and fire!
