H2 battery light ?
Old 01-12-2011, 02:45 PM
H2Promotions's Avatar
Default H2 battery light ?
Hi folks i have a 2004 h2 just done 40k i went to start it today and had a few problems...... here goes a slight clicking noise & lights go dim on the dash thats with ing on but engine not running (all things work fine)
problem 2 i noticed the battery light was on but very faint,after 1hrs driving it went off its allways shows its charging
the light is very faint
many thanks www.h2promotions.co.uk www.jrmrecovery.com
Old 01-12-2011, 08:12 PM
calif phil's Avatar
Check for a loose battery cable. If those are OK most likely you have a bad battery or Alternator.
Old 01-13-2011, 09:57 AM
Unhappy
Replaced the alternator(with new one) checked all main wires had the battery tested & had the codes read on ecu & all ok ?? but the light is still on very faint even with no keys in ............. "help its bugging me"
Old 01-13-2011, 10:17 AM
calif phil's Avatar
If the Battery light is on with the key out I would bet the Igntion Switch is bad. My 03 had that same problem. Ign switch was not expensive. I am talking about the electrical portion not the lock cylinder.
Old 01-13-2011, 10:33 AM
TheLimoGuy's Avatar
Yeah, it sounds like both problems you listed are actually related. I would look at the ignition switch first and foremost. Did you take it to dealer?
Old 01-13-2011, 05:22 PM
luda81's Avatar
Sounds to me that the wires have to much resistance. If not then the alternator is going bad. Check for corrosion and loose wires.
Old 01-16-2011, 08:28 AM
I have got to say the light is on but very dim & some times goes off
have you a part number for the ign bit ? or a pic ? cheers
Old 01-16-2011, 11:24 AM
I have had a look today & found the ignition starter pack now to find one in the uk ! & quick help...............
Old 01-16-2011, 01:02 PM
any way of checking these ??
Old 01-16-2011, 08:28 PM
calif phil's Avatar
What is an Ignition Starter pack? If you need help with a part let me know and I might be able to assist in mailing you parts from the US.
Quick Reply: H2 battery light ?
